by Chef » Sun Jul 25, 2021 10:15 pm
This is not exactly the same as my car had but a lot of it sounds simular...
in the beginning changing of fuel filter, intercooler, map sensor, checking turbo and pipes but did not fix it (yours might have some air problem)
than it was the exhaust and for some reason the dpf was changed and yes basically everything in the exhaust instead of just taking off the exhaust and take it for ride and see if it looses power.. than all the vacum system was tested and fixed... nothing had changed at that point, my friend took it in and found out that the map sensor for air in the angine was stuck in 88% , I bought new one and than than all problems when the car was taking off went away and got really good but expensive to trow out all these parts for no reason.,, than it went to ford and I said it needed to be fixed and not change just something to check.. they opened up the engine and found out had one of the solid lifters (valve controls from camshaft) broken so it did not function properly... but that did not change anything wich is weird because I had a car with broken valve and it was unusable...
after that was fixed the problem rate went down (which mostly bothers me while the car is cold, just after I start, and sometimes even if it is hot when I start it)
it was suggested to me that the injectors might be leaking and therefor to much diesel was filling up when the car was off, it was checked but was ok but quite a few smaller engine transit have this problem.
than changing egr, seals on back of the engine and pipe..
than the problem was that glow plugs where bad, fixing them made the car run much better cold because it has also afterburner, so that the glow plugs are on after you start the engine to get co2 down, but does not quite fix the problem mine is having and in the end the ford in my country just said the engine is ruined and needs to be replaced... I have driven it in this condition 14000 miles and milage today is 62000 miles total..
So my advise is start by checking the way from outside to the engine, each pipe and look through it or blow bacause animals and insects might do some clogging, than check vacuum if any pipe is broken, fuel filter, egr, dpf filter, or just exhaust road, map sensor just by the air intake, open engine and check camshaft and valves, checck if the oil fill stick is very black, than it might be the pressure is getting down to the cellar, try opening the oil fill cap and see if the pressure is stuck inside the engine, put something over so oil will not spray out from it... and yes I hopefully also got some ideas going for assistant on alike problems =)
