i have bought a ford mk1 with a diesel engine (not original) unfortunattely this diesel is trowing out the engine oil while running (after a while) the oil comes out of the oil dipstick so i supose over pressure in the engine, maybe the piston rings?
i want to do a compression test to have more information from the engine but the engine have only 1 central glow plug, can i do the thest in the injectors?
how can i disconnect to fuel pump? does i need to mark this pump when i disconnect this (is it difficult to time the fuel pump?)
where can i find the maintanance / adjustment information from this engines?
