MilesWorld wrote:Many thanks Mark,
i have been looking at this lot
http://www.rust.co.ukthey make a penetrating oil and a thinner version to be used first in bad cases,
The rust is not bad on my van, but its really bad manufacturing that designs in moisture-rust traps into vehicles, they should be coming out of the factory internally waxed,
im gonna go for a rust converter followed by 2 part expoxy primer on external rust / wax on the internal, thin then standard (shutz gun), and then again in the spring.
many thanks Miles
p.s. your sheet metal skills are awesome, i love making stuff like that - lets hope i dont have to
I'm not too sure about that rust converter ..think it does not penetrate into the rust as far as i would like it to ...it will turn the rust a blacky blue colour ..but only the first 0.5mm of it ..once dried and you scrape it with say a wood chisel you'll still see the brown stuff underneath .
Much prefer the strait phosphoric acid ..wire brush as much as you can off ..put on the acid and with more wire brushing you eventually reach un-rusted metal..then you know its right.
With rust converter ..you are hopefully sealing it in for good, then you are covering it with more products ..so when the time comes when it starts to blister it will take in more water ..it will be worse ..I say i don't have that hope ....unless you see the van as just a 5 year thing.
the underside exposed floor etc ..I've just blitzed the whole underside of a car with 1/8 inch of waxoyl in the past ...over the rust (mild rust staining) and it kept it at bay - my experience, most of my cars went to the breakers with an accumulation of faults that added up to more than they were worth.
Since owning a ford van , i see they need special care to prevent rust ..more so than any other vehicle I've owned. hopefully now I've given my van that special care ..i can just ignore any rust prevention measures and drive without worry.
The work ive put into this, will see it lasting beyond ten years ...i don't want to be doing it again ..so i do it right. and hopefully it will reward me.
Fords, i had a mk1 Fiesta (Spanish made) ...bought when it was 12 years old kept it for another 8 years before someone pulled out on me and wrote it off.
A sierra (German made) 12 years old ..rebuilt the engine and waxoyed it ..no problems with rust ..kept it for 10 years
These were years ago ...ford parts from ford in those days were at a fair reasonable price, which is how i could hold onto them for so long ...- what's happened ? example - wheel arch clips ate £9.60 each! and i hear labour at £76 an hour ..
all the best..mark
