Calbo101 wrote:What spark plugs does everyone use. There is so much conflicting info. Halfordsctried to sell me glow plugs ffs.
Update. Engine running. Had new lamda, CAT, a coil and HT lead that probably werent required. Took it for a short run and the cat was glowing red. It deffo struggles with power too. I even took offbthe middle exhaust to make dure it was getting enough air. I have noticed the new plugs that were put in are not the recommended ones (they are ngk pfr6B 3500 platinum. Foes anyonevthinkbthat vould be the issue? Any other suggedtions are appreciated.thanks
madmart132 wrote:Hi again you obviously got a few different problems
re the plugs I use bosch plugs the ngk ones are to wide a gap for lpg but motorcraft are good as well
forget about the lpg for the time being it will just complicate things for you
re the misfire , i had something similar last year after I had to change an engine on one of my vans , there is a small 1mil cable that bolts on to the back of the alternator it wasnt 100% tight and I had a lot of problems with it until I traced the problem ( it blew the centre box apart with one misfire ) look for that as its easily broken also the engine earth
Also the wires to the coils are thin and brittle look at them as possible breaking points in the ignition system
