knobby1 wrote:Tracking not happy..?? Are the tyres wearing unevenly..??
Airthies wrote:Check tyre Air pressure.
What was required for MOT? Anything that may of affected the steering/tracking, like ball joints, bottom arms, etc.
Altransit wrote:Because you don't do many miles, it could be that the tyres are now past their best with regards to age. It may be worth checking the date stamp on the tyres, because the rubber hardens with age, and grip is reduced
paulrichardson wrote:Airthies wrote:Check tyre Air pressure.
I checked the Tyre pressures and they are OK.
I had to have new front brake discs for the MOT, would that effect tracking ?
paulrichardson wrote:Altransit wrote:Because you don't do many miles, it could be that the tyres are now past their best with regards to age. It may be worth checking the date stamp on the tyres, because the rubber hardens with age, and grip is reduced
What format is the date stamp?
I have already tried to find a date, but couldn't find anything that I could decipher as a date
Altransit wrote:paulrichardson wrote:Altransit wrote:Because you don't do many miles, it could be that the tyres are now past their best with regards to age. It may be worth checking the date stamp on the tyres, because the rubber hardens with age, and grip is reduced
Four numerals on the side wall, the first two are the week of manufacture, the second two are the year.
https://www.kwik-fit.com/tyres/information/tyre-age
paulrichardson wrote:Many thanks, found it, mine are 5010.
I guess that means I really need to be looking for new ones.
Altransit wrote:paulrichardson wrote:Many thanks, found it, mine are 5010.
Yes, you're on the far end of useful life, which is a shame if they're not worn out, but it's often a problem with low mileage vehicles such as campers. I've binned many a tyre that has aged before it was worn out
It's a shame that you're not closer, as I have a set of 16s that you could have tried before you bought new ones
