Hi there,
The horn onmy transit van had stopped working. I cheked the connections, which seem fine. Ithen tapped it with a hammer with the horn depressed and this created seom honking but it was still not workingso I took it off and found that it is full of water. Is there anyway of getting the water out, and if so will this fix the problem? Or do I just need to get a replacement horn?
Thanks in advance.
Jo
