To this kind of question you'll probably get the standard safest bet answer which is "replace everything" lowest risk
but I'll chime in and stick my neck out.
What I can see of friction plate shown it doesnt look like it's worn that much apart from a peculiar heavy outer edge wear. If the other side (not shown) had reached the rivets then the clutch would slip, that's the point the friction plate reaches end of life.The coil springs don't look that battered. If there was a lot of judder then that won't usually go away after just replacing friction plate.
People often take the opportunity to change to a solid flywheel as well as full kit for extra peace of mind if it's got a cushioned drive one.
If there's a rattle noise then that's probably why you're looking at it now.
Otherwise clutches can go for many months even years with noisy release bearing rattles, and then suddenly without warning the disengage stops working and you suddenly have to learn how to change gear without a clutch (not so bad) or get a recovery.
Usually the advice is change everything after having got this far. A complete kit isn't that more pricey compared to the time you spend. Which might well be where we started because sometimes people just replace the friction plate only (I often do) and then the reused release bearing fails (or gets annoyingly noisy) before the new plate gets through its lifecycle.
