MinorMatt wrote:With an ECU are you sure its not a mk4?
PintoBill wrote:Thanks to both Chug and Matt,
The wiring info is helpful and Matt you was right on the money, I pulled that Relay on the top left of the fusebox, it looked fine but by substituting it with another relay I now have a spark on the coil. The Haynes manual I have is a 86- 89 which covers the Pinto but the wiring chart does not show this relay present in the ignition system.
Every days a school day
