Hi all,
I have an issue with my 2016 mk7 custom LWB … the issue is that the external door handle will not open the side door if the side door is closed. I can use the internal handle to open the door no problem, also If the side door is open and on the catch the external handle will engage and I can close the door without an issue, so it’s just when the side door is closed the external handle won’t ‘engage’. I have take the cover from the inside of the door, when I hold the cable and try to operate the external handle I can feel the cable moving, do you think it could be the lock causing the issue the other end of the cable?
Any help would be greatly appreciated, thanks all.
Have a great Sunday
