Mk7 Light bulbs
Mk7 Light bulbs
Postby Uncle_Fester » Fri Oct 15, 2021 5:13 pm
Hello all, probably a newbie question but the manual doesn't say.
What type of headlamp bulbs are fitted, is it a canbus system and can I use LED bulbs..
(2013 2.2 tdci)
Cheers
Fester
(Mk7 2.2tdci jumbo highroof twin wheel 17 seat minibus.)
Uncle_Fester
Re: Mk7 Light bulbs
Postby Altransit » Fri Oct 15, 2021 5:51 pm
Fitted are H4 Halogens, and yes, it has a Can-Bus. Not sure about LED bulbs, I've never tried.
Re: Mk7 Light bulbs
Postby Uncle_Fester » Fri Oct 15, 2021 6:43 pm
Altransit wrote:Fitted are H4 Halogens, and yes, it has a Can-Bus. Not sure about LED bulbs, I've never tried.
Thanks, I'll not bother with LED's don't want to upset the computer .....
H4's it is
Fester
Uncle_Fester
Re: Mk7 Light bulbs
Postby Mike » Fri Oct 15, 2021 7:31 pm
You'll find the any high output bulbs will be a waste of money in MK7 headlights. Correctly aligned Osram Nightbreakers will be more than adequate though.
Mike
Wind up merchant!
Re: Mk7 Light bulbs
Postby Altransit » Fri Oct 15, 2021 8:30 pm
H4's it is
Fester
The can-bus may not extend to the lighting circuits, I just assumed that it did, but as Mike has said, the standard headlight reflectors don't work well with LEDs or HIDs, but a good quality H4 will make a difference over the standard ones.
I've used Philips Extreme, and Osram Nightbreakers in mine, both with good results.
Re: Mk7 Light bulbs
Postby knobby1 » Sat Oct 16, 2021 10:36 pm
I have LED H4's in mine....MUCH better than the stock candles.
Re: Mk7 Light bulbs
Postby paulrichardson » Fri May 20, 2022 9:16 am
knobby1 wrote:I have LED H4's in mine....MUCH better than the stock candles.
Sorry to "wake up" an old thread but I wondered if you could remember the make of your LED H4 bulbs.
I've seen them at so many different prices, I don't know where to go :?
paulrichardson
Re: Mk7 Light bulbs
Postby knobby1 » Fri May 20, 2022 9:44 pm
These are the ones l have, much better than the stock halogen candles..:
https://www.ebay.com.au/itm/Nighteye-H4 ... ect=mobile
Re: Mk7 Light bulbs
Postby paulrichardson » Sun May 22, 2022 5:23 pm
Thanks for that, I've found the same make on the UK ebay.
Just before I order some, what was the beam pattern like?.
Thanks,
paulrichardson
Re: Mk7 Light bulbs
Postby knobby1 » Sun May 22, 2022 8:43 pm
Thanks,
If your headlamps are original Ford units and the little square silver shroud piece at the front of the bulb in the headlamp assy is there, it will be fine as long as you install the LED vertically, if horrizontal, the beam is useless.
Re: Mk7 Light bulbs
Postby paulrichardson » Mon May 23, 2022 9:19 am
Many thanks :D
paulrichardson
