Mk7 bottom door pockets
Postby GSDGuy » Tue Oct 19, 2021 9:16 am
Hi
Are the bottom door pockets on Mk7 interchangeable or are they distinctly different?
GSDGUY
GSDGuy
Re: Mk7 bottom door pockets
Postby steve58 » Tue Oct 19, 2021 7:56 pm
Hi the bottom door pockets are the same,I fitted a pocket at the bottom of the drivers door,the only problem is the front fixing is the same as the door card,I cut the fixing hole off and fitted no problem
steve58
Postby GSDGuy » Mon Oct 25, 2021 10:02 am
Hi bud- so you did without one fixing bolt is that correct?
GSDGuy
