Dual battery system w/Euro6 and S&S
Postby Blizz » Mon Oct 25, 2021 6:52 am
Hi,
I'm currently waiting for my new Transit to arrive so I'm trying to source info and items to install once it gets here.
I'm a bit confused about the dual battery system... I've read quite a lot about the way the smart alternators work on those Euro6 so I understand I need a booster (Or DC-DC Charger) but I'm quite confused about the Start&Stop system.
I read about a connector on the mk7s that has current when ignition is on, but nothing about the newer mk8 (Mine will be a 2.0 Ecoblue Euro 6.2 with S&S).
Supposing I find a signal for triggering my DC-DC Charger, if that signal is like the mk7 one it will not be the ideal, as it only says ignition is on but not the engine is on. I mean, I don't want the mail battery giving amps to the secondary when you're stopped in a red light with the engine stopped, for example...
I've seen there are some D+ Simulators but could not find any info about those.
How would you install a dual battery system on a S&S mk8?
Thanks in advance,
David
Blizz
Re: Dual battery system w/Euro6 and S&S
Postby dumper » Mon Oct 25, 2021 10:05 am
there are smart b2b charges about that don’t need a ignition feed and are just connected to the van battery’s I use a Sterling one on my 2015 2.2 euro 6 bus for them you can get a lead from Ford that plugs into a connector under the drivers seat it may be worth having a word with Ford to see if this is available for your later van if you get a unit that needs a ignition feed.
Postby Blizz » Mon Oct 25, 2021 10:19 am
I'd prefer to use an auto one like the Sterling you named.
I know I can get that OEM adaptor for that plug but it's quite expensive for only using one wire, I can crimp a connector or something.
BTW, does that connector have a signal when the engine is ON (Not ignition but engine running?).
Is this the one you've?
Thanks for your help!
David
Blizz
Postby dumper » Mon Oct 25, 2021 10:33 am
No mine is the 75 amp one and no solar function.when I thought I had a problem with mine I did fit a live feed to it from the connector in the seat box and did use a crimp on terminal and I think that when I tested it out it was on when the ignition was on so if you use stop start it will probably still be energised on my van I’ve had the stop/ start turned off so mine will only change when I have ignition on and running the engine.
Postby Cider Andy » Tue Oct 26, 2021 5:35 pm
Mk7 DOES have an "engine running" signal wire so I'm sure the Mk8 will, especially with it having stop/start. Try to get hold of a BEMM (Body & Equipment Mounting Manual) for it, I'm sure it will be in there.
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
Postby Blizz » Tue Oct 26, 2021 5:36 pm
Thanks Andy, I'll try to find the BEMM.
Cheers,
David
Blizz
