Ashley S wrote:When you mention correct factors is that the code on top of the injectors for the programming?
knobby1 wrote:Ashley S wrote:When you mention correct factors is that the code on top of the injectors for the programming?
Yes, it's a 16 digit correction factor code, each injector has an individual number. No two injectors are the same even though they share the same part numbers. This number tells the PCM the calibration of that injector and how long the injector should be opened for during the pilot and main injection cycles.
Likewise with the pump, SCV and PRV. This is why the learns need to be done when replacing any fuel component.
Ashley S wrote:knobby1 wrote:Ashley S wrote:When you mention correct factors is that the code on top of the injectors for the programming?
Does the fuel pump, and SCV, PRV need learning before programming the injectors?
Ashley S wrote:Transit 2.2 MK7 115BHP 2011. I was at the lights today with my van in neutral the engine started to shake a little and the revs starting moving up I have to put my clutch down for it to go back to 800 revs. Bare in mind I have a problem with my Injectors not programming, learning etc. Mechanic is not interested I've paid him £800 for recondition injectors and a brand new PRV and SCV cost me £300 from Fords. I have a lot of white/grey smoke at night time and if I go on a long motorway run in 6th gear and when I give it a boot there's a lot of black smoke. I have been told my engine is not running right with the injectors I have installed on the engine it's over fuelling I've been told.. I am no means a mechanic. I am worried I might burn the piston if it's programmed and learned?
knobby1 wrote:Ashley S wrote:Transit 2.2 MK7 115BHP 2011. I was at the lights today with my van in neutral the engine started to shake a little and the revs starting moving up I have to put my clutch down for it to go back to 800 revs. Bare in mind I have a problem with my Injectors not programming, learning etc. Mechanic is not interested I've paid him £800 for recondition injectors and a brand new PRV and SCV cost me £300 from Fords. I have a lot of white/grey smoke at night time and if I go on a long motorway run in 6th gear and when I give it a boot there's a lot of black smoke. I have been told my engine is not running right with the injectors I have installed on the engine it's over fuelling I've been told.. I am no means a mechanic. I am worried I might burn the piston if it's programmed and learned?
You need to take it to someone who knows what they're looking at....or.....download Forscan and get yourself a modified ELM-327 and do it yourself.
Check to make sure the clutch switch is operating correctly.
Until the learns are completed successfully, it will "never" run properly.
Ashley S wrote:Would it be best not to let it idle when I am not in the van? I am worried if it becomes a run away engine.
knobby1 wrote:Ashley S wrote:Would it be best not to let it idle when I am not in the van? I am worried if it becomes a run away engine.
Will only "runaway" if the turbo is shot and leaking a silly amount of oil into the inlet system.
Ashley S wrote:knobby1 wrote:Ashley S wrote:Would it be best not to let it idle when I am not in the van? I am worried if it becomes a run away engine.
I don't think the turbo is shot there's plenty of power in the turbo.
