dumper wrote:When you did a compression test did you do the first one and then do a second one after squirting some oil in the cylinder to determine if it’s valves or piston rings/ piston if it’s the valves the readings will be the same if it increases then it maybe piston/ rings problems.
andz327 wrote:YOU BETTER CHECK YOU'VE NOT GOT TIGHT TAPPETS AFTER FOOKIN ABOUT WITH THEM
Sent from my SM-G975F using Tapatalk
SET THEM TO WHAT THEY SHOULD BE DON'T GUESS, HOW OFTEN HAVE YOU TIGHTENED THEM ?gasbo wrote:andz327 wrote:YOU BETTER CHECK YOU'VE NOT GOT TIGHT TAPPETS AFTER FOOKIN ABOUT WITH THEM
i'll try opening them up more..see if that cures it
andz327 wrote:SET THEM TO WHAT THEY SHOULD BE DON'T GUESS, HOW OFTEN HAVE YOU TIGHTENED THEM ?gasbo wrote:andz327 wrote:YOU BETTER CHECK YOU'VE NOT GOT TIGHT TAPPETS AFTER FOOKIN ABOUT WITH THEM
DID YOU ADJUST TWICE IN A MONTH DUE TO IT BEING NOISY/ CAMMY/ TAPPETY OR SOME OTHER REASON????gasbo wrote:the only other thing i can think of is i used semi synthetic oil instead of mineral oil..that wouldnt f*** it up would it?
andz327 wrote:DID YOU ADJUST TWICE IN A MONTH DUE TO IT BEING NOISY/ CAMMY/ TAPPETY OR SOME OTHER REASON????gasbo wrote:the only other thing i can think of is i used semi synthetic oil instead of mineral oil..that wouldnt f*** it up would it?
