Steve192 wrote:Hi people, I’m after a little bit of help with my van. It’s a 2012 2.2 fwd euro 5 van.
My hill start assist stopped working so I searched on here and found the thread explaining the 3 pedal push down method to turn it on and off. I tried this and it didn’t work however, I have a massive list of fault codes now on the abs module. I used forscan to do a self demand test on the abs module and it came back with no errors, I also set the longitude sensor (or whatever it’s called) and also the steering angle sensor too. Still have the lights on. I have the abs, esp and handbrake light on constantly.
Today I changed the front 2 abs sensors, didn’t solve the problem. Could it possibly be the rear abs sensors? Seems funny how it only started once I tried the 3 pedal hill start assist method. Could I have possibly fried the abs module doing this?
I’ve attached photos of the fault codes all relating to the abs module.
Any help would be greatly recieved. It’s driving me mad as it’s showing no issues with the abs module on forscan tests.
Cheers
Altransit wrote:Do you have cruise? Is it working
Altransit wrote:Ah OK, I was going to suggest checking the switches on the clutch and brake pedals. These can disable all sorts of things if they aren't working.
Steve192 wrote:Altransit wrote:Ah OK, I was going to suggest checking the switches on the clutch and brake pedals. These can disable all sorts of things if they aren't working.
It’s strange that this has only happened because I tried the method to turn on or off you hill start assist. I literally just turned the ignition on, pushed all 3 pedals down for roughly 10 seconds then released them and now my dash is lit up like a Christmas tree. That method clearly didn’t work for me.
knobby1 wrote:Steve192 wrote:Altransit wrote:Ah OK, I was going to suggest checking the switches on the clutch and brake pedals. These can disable all sorts of things if they aren't working.
Does your van actually have hill assist available..??
547 HEW wrote:I have just got this very same issue on my 2008 MY Medium wheelbase low roof, fwd with 2.2 TDCI 110 PS engine. I have owned from new and its on 92k miles. Its got cruise control which is still working fine.
I think the Hill Start assist may not been operational for a few days, then yesterday driving at 60 mph into a very strong headwind at about 3 deg C and a bit wet, then both lights came on simultaneously. They stay on, on key on, and there's no shifting them!
This morning I connected the diagnostic kit, but no DTCs, which is baffling to say the least.
Next step will be to get under it and look for any visible evidence.
Of course, it would be interesting to know if the OP solved his issue.
Thanks for any suggestions
547
