Canbus wiring
Canbus wiring
Postby Bowtay » Fri Mar 25, 2022 7:45 am
Does anyone have a canbus diagram for a 2010 transit I need to see what's on the system as I have no start no comms and 1.3 volts on can line
Sent from my SM-G973F using Tapatalk
Bowtay
Re: Canbus wiring
Postby andz327 » Fri Mar 25, 2022 10:15 pm
Have you plugged in to read any fault codes ??
Sent from my SM-G975F using Tapatalk
andz327
Re: Canbus wiring
Postby amlav » Thu Mar 31, 2022 6:32 am
Check the obd port , maybe it was converted to anti theft port . Sorry got no diagram of the obd port wiring but try Google it up and see how you go.
amlav
Re: Canbus wiring
Postby Bowtay » Sat Apr 09, 2022 12:10 pm
Thanks for the reply found the problem wires were broken going to engine fuse box they had been badly repaired previously
Bowtay
Re: Canbus wiring
Postby Bobble123! » Mon Apr 11, 2022 7:01 pm
Based on my VWG knowledge, be mindful when repairing CAN wiring to keep the same twist rate on the repaired section. Offset the crimp terminals used too.
The twist rate can affect the ability of the network to cope with interference 8)
Bobble123!
Re: Canbus wiring
Postby Bowtay » Mon Apr 18, 2022 7:18 am
Thankyou for that info
Bowtay
