Low revs advice needed
Postby Edward Lyons » Mon Apr 11, 2022 9:28 pm
I have a 2013 T350, it won’t Rev over 3,300rpm, tried changing the DPF pressure sensor and it’s still the same. Any advice welcome
Edward Lyons
Re: Low revs advice needed
Postby knobby1 » Tue Apr 12, 2022 1:02 am
Edward Lyons wrote:I have a 2013 T350, it won’t Rev over 3,300rpm, tried changing the DPF pressure sensor and it’s still the same. Any advice welcome
Why did you change the DPF sensor..?? Is the DPF blocked..?? Regen working..??
Postby Jim Archer » Tue Apr 12, 2022 6:28 am
Did you have the codes read? Or just guess?
Check the clutch and brake switches on the pedal box.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
