Evening folks.
After several attempts at changing the oil in my 99 transit I've given up once again, my issue is undoing the sump plug! Tonight I showed it a brand new set of milwaukee stilsons (borrowed) to no avail.
Question, could it be left hand thread? Im left with a nugget of the original plug, just enough to weld a nut to all being well, but still then I fear chewing the nut off.
Ive read on here tighten to 23 NM think mine is upto 230 nm!
Failing that its going to have to be a new,sump.
Im wondering due to the amount of engine oil leaks if the previous owner chose the top up method rather than a full oil change.
