by knobby1 » Wed May 25, 2022 8:48 pm
Harley 1990 wrote:Changed oil. Did not get better. Flywheel and clutch have just been replaced. Gears up and down nicely. Does anyone have good ideas about what makes noise in the gearbox.
Does the gearbox also rattle when in neutral with clutch out..?? If so, it's usually the 1st motion, (input) shaft bearing or gear not happy...but could be other gearbox internals causing grief when under load. Either way it's a gearbox out job to sort it....probably easier/cheaper to just replace the gearbox.
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3DLord Knobrot
