Wheel noise?
Wheel noise?
Postby Hedgie » Sun Apr 17, 2022 10:31 pm
I have a strange noise which appears to b coming from the front wheel. The best way I can describe it is that it sounds like the chuff chuff noise of a steam train.
Noise is there either in or out of gear but does seem to speed up the faster I go hence I assume it's wheel related?
Any suggestions? Is it brakes, bearings or something else?
2007 '07' Mk7 Transit MWB minibus 15 seater
2011 '11' Mk7 Transit SWB minibus 12 seater - sold
2001 'Y' Mk6 Transit lwb minibus 15 seater - deceased
1999 'V' Mk5 Transit lwb minibus - deceased
Hedgie
Re: Wheel noise?
Postby metalworker0 » Sun Apr 17, 2022 11:05 pm
first check wheel nuts are tight ..
if they are :
could be a warped disc,
or possibly , you've had new tyres recently ...and disc has come loose, (entirely possible as the discs are held on with the wheels) disturbed rust has fallen down the back of it as wheel was replaced
all the best..mark
Re: Wheel noise?
Postby andz327 » Sun Apr 17, 2022 11:21 pm
What model of transit ?
Sent from my SM-G975F using Tapatalk
andz327
Re: Wheel noise?
Postby Hedgie » Sun Apr 17, 2022 11:24 pm
2007 Mk7 MWB minibus.
Not had new tyres recently.
Hedgie
Re: Wheel noise?
Postby fortyeight » Tue Apr 19, 2022 7:51 pm
wheel bearing
fortyeight
Re: Wheel noise?
Postby Jim Archer » Wed Apr 20, 2022 5:35 pm
Jack each wheel and spin them.
Might be a low pad starting to catch a wear lip.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: Wheel noise?
Postby Hedgie » Thu Apr 21, 2022 6:49 pm
Thanks for all the responses guys. I will get the wheels off and check it out tomorrow.
Hedgie
Re: Wheel noise?
Postby fortyeight » Wed Apr 27, 2022 10:36 pm
what were the out come
fortyeight
