Drive shaft intermediate bearing carrier
Postby Diveoverland » Sun May 01, 2022 8:58 am
I've got a 6 speed 2012 2.2tdci, fwd, 100hp box van, i had a new righthand drive shaft fitted as the support intermediate bearing had siezed. The bearing has badly worn the bearing support bracket and clamp and i cannot find any parts or numbers except for a 5 speed and its different.....no part numbers on the assembly either.
Also on the nearside drive shaft the actual circular shaft moves a good 1/2 inch in and out, is this excessive?
Diveoverland
Re: Drive shaft intermediate bearing carrier
Postby Frag » Sun May 01, 2022 1:08 pm
6 speed bearing bracket 1520289 states ‘sold out’ on eBay
4559309 for the retainer. £4 on eBay
Frag
Ford Technician
Postby Diveoverland » Sun May 01, 2022 5:56 pm
Cheers but that says the retainer is for a 6 speed auto Durotorq 2. Are they the same?
Diveoverland
Postby Frag » Sun May 01, 2022 6:18 pm
It may fit others,
But thats the number listed for mk7 6 speed vmt6
I used catcar.info
Frag
Ford Technician
Postby Diveoverland » Sun May 01, 2022 7:27 pm
Yes it does, thank you, maybe thats the one then
Diveoverland
Postby knobby1 » Sun May 01, 2022 9:29 pm
Diveoverland wrote:Cheers but that says the retainer is for a 6 speed auto Durotorq 2. Are they the same?
Does this help..??
http://www.catcar.info/ford/?lang=en&l= ... EzMQ%3D%3D
Postby Diveoverland » Mon May 02, 2022 3:35 am
Yep, found that, thanks.
Diveoverland
