Hi guys, read a few posts on this issue on here but not really answering my issues.
I bought a 2003 transit connect with a clock function issue. The van runs ok but the usual I’m told that the clocks are temperamental and the gauges didn’t work and both lcd displays were blank.
Thought about replacing them with a second hand matching part number set but seeing it was an easy fix so I’m told and decided to sent them away to be repaired.
I’ve received the back 3 days later and £65 poorer thinking all good and refitted the clocks. Thinking I was in luck the clocks came on both lcd panels came on and the fuel gauge moved. All the relevant lights light up aswell
BUT to my dispare when I tried to start the van over all you hear is clicking. As if the starter motor isn’t working.
just thought I’d as all you experienced transit owners for advice before reading every video and post I can find that might point me to a simple solution.
1 thing I have noticed was when I try to start the the van the time clock resets to Zero Don’t know wether it’s relevant
