lift pump obsolete for VH Transit van
Postby Geoff B » Tue May 24, 2022 10:04 am
The lift pump has stopped working on a VH van year 2000 the lift pump is electric also filter body is leaking thus letting in air. I cannot hear pump start or run at all. Fords informed me that these parts are obsolete. so can somebody help me to stay on the road?
Geoff B
Geoff B
Re: lift pump obsolete for VH Transit van
Postby Altransit » Tue May 24, 2022 11:40 am
This is what we call a Mk6 in the UK (so I believe!), there is no lift pump on these, unless for some reason, your Aussie vans are different :?
Postby ned » Tue May 24, 2022 1:05 pm
Didn’t the early mk6 120ps have the lift pump shown? Think it was only a 2 year thing.
As the rest of the mk6’s didn’t have the lift pump surely you could fit a new filter housing that doesn’t have the lift pump and the van should work.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Geoff B » Tue May 24, 2022 3:09 pm
please what does the 120PS stand for Ned
Geoff B
Postby metalworker0 » Tue May 24, 2022 3:28 pm
PS is a sort of metric horse power, about 2% less than normal horse power.
so your transits engine power is 120 metric ps
Postby Geoff B » Tue May 24, 2022 3:33 pm
thanks guys there's a glimmer of hope here for me. my engine is a Duro tork does that make a difference please?
Geoff B
Postby ned » Tue May 24, 2022 4:45 pm
All mk6 are duratorq engines, yours will be a tddi 120ps possible, it should say on the front doors 120t350 or something like that the first number is ps I.e 75, 95, 110 ect and the T is max gross weight I.e 280, 300,330 or 350.
Nearly all mk6’s didn’t have lift pumps.
Hope that helps.
ned
Postby knobby1 » Tue May 24, 2022 8:37 pm
As mentioned by the other lads..."ALL" Mk6 and Mk7 diesel engines are "Duratorq", not duro tork.
The early 120/125 Mk6's had the lift pump on the fuel filter assembly. So I'm guessing you have a 2.4 RWD 120/125PS. You will have a VP-44 fuel pump.
As our Ned mentioned....You can actually fit a filter assembly from another Mk6 (without the lift pump) and it should run fine. It was deleted on the later models. Some even had a hand operated primer pump on top of the filter housing.
http://www.catcar.info/ford/?lang=en&l= ... NzkyKzA%3D
Postby Geoff B » Wed May 25, 2022 3:30 am
Thank you so much for the info from members it is helping me so much and I am so grateful this is a very helpful forum.
Geoff B
Geoff B
Postby Geoff B » Sat May 28, 2022 2:27 pm
Hello all, I have a new fuel filter with housing coming it has a built in hand pump on top of housing how do I use this please?
I know I have to fill filter to the brim with diesel but then I am stuck.
Geoff B
Postby shambles007 » Mon Aug 12, 2024 3:09 am
knobby1 wrote:As mentioned by the other lads..."ALL" Mk6 and Mk7 diesel engines are "Duratorq", not duro tork.
Hi Lord Knobrot,
My VH 2.4lt 90/350T 2002mdl suffered the similar fate about a year or so back. I now need it for work again, so I got all motivated to repair it.
So a year or so back the lift pump died (no lift pump sound at ignition and no start), found a good second hand lift pump and replaced it. Drove it for approx one month after that, no issue. A month or so later couldn't start it again. Thought is was lift pump again so mucked around with it on and off for a few days. Zilch, nothing, nada, wouldn't start. Got busy with work again so jumped into one of our VM's and the VH has just sat since.
Can a dead lift pump can cause overheating in the VP30 and fry's circuit boards and diaphragms etc? I also read somewhere to diagnose a faulty VP30, you should get a minimum of 2.5K ohms resistance between pins #6 and #7 and also 60 ohms between #1 and #2. Is this accurate? Any help appreciated.
You also mention the lift pumps can be deleted. Do they start OK without issue after the delete?
Been reading your posts for years which have been extremely helpful, so really appreciate that!
Any pointers you can help with is much appreciated!
cheers shambles007
shambles007
