installing roof vent into ridged roof
Postby Transitary » Tue May 31, 2022 9:35 pm
Hi all, Just joined with a newly aquired Mk6.
Roof skylight was leaking badly on first night of use.
Found the skylight was a complete mess of silicon sealent on roof and not suprised it was leaking.
Decided it was best to remove it and start again with new skylight or vent.
Can anybody give me advice on how best to install/seal it in the ridged roof.
and any advice on skylights . This one is right sizehttps://www.ebay.co.uk/itm/283301560948.
thanks in advance
Transitary
Re: installing roof vent into ridged roof
Postby bortaf » Thu Jun 02, 2022 10:08 pm
Somewhere on the net there a bloke who makes 3D printed adapters to go in the ribs and make a level surface to seal to ?
other than that i usually fill the dips with Mastic Sealing Strips and then sika the mating area, i never use normal selaer like silicon, it tends to shrink with UV IME, something like sikaflex 522 caravan :)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Transitary » Fri Jun 03, 2022 12:31 am
Transitary wrote:Hi all, Just joined with a newly aquired Mk6.
thanks in advance
Thanks for the info. I will look for adapters.
Transitary
Postby straydog » Fri Jun 03, 2022 12:09 pm
bortaf wrote:other than that i usually fill the dips with Mastic Sealing Strips and then sika the mating area, something like sikaflex 522 caravan :)
Exactly how I did mine.
No leaks in the 5 years fitted :)
straydog
Postby Blizz » Sat Jun 04, 2022 11:48 am
The adaptor are made in the US:
https://diyvan.com/collections/transit
Cheers,
David
Blizz
