Miisu123 wrote:Hello. I replaced front breaks and left driveshaft. After that it wont move. Every gear goes on, but clutch pedal doesnt do anything. Pedal goes up and down. Gears shift smoothly even with pedal up. Checked lines and bleeded the clutch with vacuum pump. Still nothing. Driveshaft seal seems to leak gear oil, but that shouldnt affect the clutch? Any ideas what to do? Thank you
