Mk7 Transit 2.2 FWD Code P0642
Postby Duggy33 » Fri Jun 03, 2022 4:49 pm
Hi guys, I have bought a non runner with the P0642 code. Are there any pointers to get me started please? Thanks
Duggy33
Re: Mk7 Transit 2.2 FWD Code P0642
Postby marc1234567 » Sat Jun 04, 2022 10:19 am
Did a quick search to get started, not sure how useful the advice is but they are saying common problem and one of the batteries. I've no experience with bad sensors. seems odd there is no other sensor specific info. possibly sensor fault codes would come up if this issue is resolved .
viewtopic.php?t=172240
found through Google. not that many posts here
https://www.google.com/search?q=site%3A ... rg+p0642+&
is there any history the seller told you about ti narrow it down perhaps?
an idea to physically check wiring to various sensors although am wondering g if pcm itself could be at fault ( one of the thingsi read as a possibility, but for
another vehicke)
I would want to see the codes myself if I were you . I.ebuy a forscan elm 327 hardware ( cheap on ebay) less than£20 and using the free forscan software. it may well not give you any more info though I guess.
Previous mk 5 (2000) Luton body (2012-2013)
Mk 6 tddi 2.4 125ps RWD dropwell luton (2018 - present)
Mk 7 tdci 2.2 125ps RWD Luton / taillift (Aug 2021-present)
marc1234567
Postby knobby1 » Sat Jun 04, 2022 9:50 pm
Duggy33 wrote:Hi guys, I have bought a non runner with the P0642 code. Are there any pointers to get me started please? Thanks
Twin batteries..?? If so, check the front one...and get it properly load tested.
Postby Duggy33 » Sun Jun 05, 2022 2:51 pm
Thanks for the reply guys. I cleared the other code that was in at the start but it has come back again. So I have P0642 and 1409 EGR vacuum reg circuit, still not starting. Possibly related to PCM?
Duggy33
Postby Duggy33 » Sun Jun 05, 2022 2:52 pm
Thanks for the reply guys. I cleared the other code that was in at the start but it has come back again. So I have P0642 and 1409 EGR vacuum reg circuit, still not starting. Possibly related to PCM? And just the one battery behind the seat.
Duggy33
Postby knobby1 » Sun Jun 05, 2022 8:09 pm
Duggy33 wrote:Thanks for the reply guys. I cleared the other code that was in at the start but it has come back again. So I have P0642 and 1409 EGR vacuum reg circuit, still not starting. Possibly related to PCM? And just the one battery behind the seat.
What code reader was used..?? Mk7 EGR's don't have a vacuum circuit, they are electronic.
Postby marc1234567 » Sun Jun 05, 2022 8:12 pm
pretty sure the battery nearest the front. Back one is for starter and front for the rest.
marc1234567
Postby Duggy33 » Sun Jun 12, 2022 3:55 pm
Just to update on the issue I had. It was a faulty EGR valve. Once I disconnected the EGR it started on the key. Renewed the valve and Bobs your uncle. Thanks for your advice along the way guys
Duggy33
Users browsing this forum: knobby1
