by dumper » Sat Jun 11, 2022 1:25 pm
I got Ford to remove mine and the speed limiter but they would only do it once the the bus was logbooked as a camper but that was mainly for the limiter before you remove it it needs the mileage transferred to the van dash.When I had mine done I had a new battery fitted in the Tachograph because I was selling it on because if you let the internal backup battery go flat on some types it will ruin it. Not sure if Forscan can transfer the mileage or you need someone with IDS someone more Tec savvy will popup and confirm what is needed.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
