Hi all.
Hoping someone might be able to give me a clue.
I have a mk7 transit 2.2 125ps
Recently I have been getting an issue where the van feels as if it is wobbling/shaking. Particularly as I am at cruising speed between 50-70mph. Once the shaking starts it seems to just keep getting worse until I pull over and stop for a moment, it may then be ok again for a while.
I had originally wondered if it could have been tyres, took it in for a check and needed 3 new tyres, so was hoping that would sort it. However today it started doing it again.
I have noticed that if I dip the clutch or stop accelerating, it stops immediately, but instantly starts again when I put my foot down. When the shaking starts, it also feels as if I am not getting the full power from the acceleration that I am applying either.
I am asking on here, because I have already taken it into the garage for them to investigate, and they found nothing they thought to be a problem. They rebalanced wheels and gave it a full service but otherwise said it was fine.
It definitely doesn't feel fine and worried that it will break down if I keep using it.
The first time it happened I did get an engine warning light which disappeared the next day, and garage said it wasn't displaying any fault codes. Around the same time the esp light was also coming and going regularly. Both of these things have stopped now. but wondering if it could be linked?
Thank you to anyone who takes time to answer, I am at a loss and not sure what to do.
