Altransit wrote:Won't a rubber plug laced with mastic/seam sealer do the job
ned wrote:Altransit wrote:Won't a rubber plug laced with mastic/seam sealer do the job
Aye but the op did ask the best way even this should do the job as long as there is no rust around the holes.
Chefgage wrote:ned wrote:Altransit wrote:Won't a rubber plug laced with mastic/seam sealer do the job
Thanks for that. Looks like what I was after. Would like to not have to weld if possible. There is minimal rust around the holes, no rot. The rust can easily be cleaned up.
That filler should do it as it has fibre in it, just make sure the underside gets some protection on after filling.
What should I be putting on the underside, more of the product?
Underseal, stone chip, seem sealer it’s up to you, just something to stop any moisture/salt ect getting into the repair, on my old van I painted the underside yearly with hammerite to hold the rust at bay.
Chefgage wrote:Do you Reckon the big boy stuff would seal a hole from a diesel heater. The hole is about 5" in diameter.
ned wrote:Chefgage wrote:Do you Reckon the big boy stuff would seal a hole from a diesel heater. The hole is about 5" in diameter.
Might be a wee bit big that, I’d be tempted to do what metalworker said for that
