Mk7 to mk8 tipper tail lights.
Postby Bigandyloan » Thu Sep 15, 2022 9:55 pm
I am currently upgrading my mk7 tipper tail lights to the mk8 ones
I have purchased the wiring harness upgrade from eBay which is meant to be a plug and play
But the connector plug doesn’t fit the vehicle plug. Has anyone done this and how did you get the lights wired up
Bigandyloan
Re: Mk7 to mk8 tipper tail lights.
Postby dumper » Fri Sep 16, 2022 4:27 am
You could get a sealed water Proof box bolt it to the chassis with chocolate block connectors inside
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby ned » Fri Sep 16, 2022 7:39 am
You could uses those heat shrink solder tubes.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Bigandyloan » Fri Sep 16, 2022 7:48 am
Do you think. Just cut the plugs off the harness?
And solder the wires ?
Bigandyloan
Postby ned » Fri Sep 16, 2022 8:38 am
That’s what I would do, cut the wires and use these
ned
Postby dumper » Fri Sep 16, 2022 10:55 am
ned wrote:That’s what I would do, cut the wires and use these
They used them at work on the PSVs but they started using the box method as they still had problems with them this wasn’t me doing the job but the company auto electrician .after that they Had no more problems.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby ned » Fri Sep 16, 2022 11:37 am
I’ve not had any trouble with them but I do use normal heat shrink tubing over the top.
ned
Postby Transitman2222 » Sat Jan 20, 2024 9:38 pm
Hi mate did you manage to cut and rewire the wires? I'm trying to do the same but unable to find anywhere on what wires on the mk8 lights to wire to the mk7 plugs
Transitman2222
Postby MAG26 » Mon Feb 19, 2024 7:33 am
Transitman2222 wrote:Hi mate did you manage to cut and rewire the wires? I'm trying to do the same but unable to find anywhere on what wires on the mk8 lights to wire to the mk7 plugs
I’ve got the same issue any update would be appreciated
MAG26
