Leak on steps
Leak on steps
Postby FritzZeus » Thu Oct 27, 2022 3:19 pm
Hello all - I’ve just replaced the door rubbers and too weather strips with brand new parts and water is still getting in. It’s not as much as previously admittedly, however it’s still getting in and settling in the step channel towards the wheel arch of the step. Any ideas as I’m losing the will to live???
FritzZeus
Re: Leak on steps
Postby joinerman » Thu Oct 27, 2022 6:52 pm
Remove the rubber again and along the area it’s leaking use a pair of wide nosed mole grips and bend the seam the rubber sits on towards the door, this will make a tighter fit when the door is closed, another way is with a short piece of 2x1 timber say six inches and put it end on to the seam and hit it with a hammer
joinerman
Re: Leak on steps
Postby mallood » Fri Oct 28, 2022 1:38 pm
Is your door bent? mine was and what i did is place a big beam at the bottom of the door so you cant close it but you create space to press out any misformations, role down your window and start pressing to top of your door, but this could be easily inspected just by looking at your door when its closed, and you should be able to tell where there is more room then it should have.
mallood
Re: Leak on steps
Postby gotgcoalman » Fri Oct 28, 2022 11:29 pm
Buy some Wellington's
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Re: Leak on steps
Postby bortaf » Sat Oct 29, 2022 2:04 am
screen trim clips ?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
