Injector wiring issue
Postby 2sipstips » Sun Nov 06, 2022 5:30 pm
Hi everyone.
Sorry about this one, I have used the search feature but to no avail.
Have a “small” technical issue which I’m hoping someone could help with… I seem to have a disconnected wire that connects to my injectors, it runs across the top of the injectors from right to left as you look into the engine bay and is connected to each injector by a small grey connector, it seems like it runs from the fuse box or ecu to the injectors and then over the back of the engine. I’ll post some photos, as I’m struggling to find where it’s come unplugged from if anybody could help I’ll be eternally grateful
2sipstips
Re: Injector wiring issue
Postby Frag » Sun Nov 06, 2022 6:33 pm
For the aircon compressor clutch,where fitted.
See here also;
viewtopic.php?f=5&t=218701
Frag
Ford Technician
Postby 2sipstips » Sun Nov 06, 2022 8:29 pm
Thanks a lot for your reply!
So if the van doesn’t have a/c where would it have been plugged into?
I think it came out when I yanked at the air box whilst removing it. Is it likely to cause me any issues?
Thanks again!
2sipstips
Postby knobby1 » Sun Nov 06, 2022 8:52 pm
2sipstips wrote:Thanks a lot for your reply!
Thanks again!
Doesn't plug in anywhere if you don't have A/C. Most transit wiring looms are the same and it depends on the vehicle equipment level as to what is plugged in or not.
Some vehicles have A/C, external temp sensor, fog lights etc....and some don't, but the wiring looms are mostly the same for each, the unused plugs are usually taped or clipped up out of the way.
Postby 2sipstips » Sun Nov 06, 2022 8:59 pm
Thanks again!
Thanks a lot for the reply, I’ll just go ahead and clip it up out of the way.
Having some smoke issues and running rough so was hoping this was the reason, as it comes directly off the injectors. At least I know now that it’s not that and I can move on!
Thanks again
2sipstips
