Battery light on dash
Postby jacky » Tue Nov 15, 2022 10:22 pm
Evening,
Tonight when coming home from work my battery light came on.
Checked the voltage and got these readings:
Engine off :12.3v
Running No Lights: 12.14v
Running with Lights: 11.89v
Running with lights, radio, heater: 11.70v
Is this a sign the alternator has gone?
jacky
Re: Battery light on dash
Postby Altransit » Tue Nov 15, 2022 10:24 pm
From looking at those voltages, yes, it's had it :(
Postby jacky » Tue Nov 15, 2022 10:48 pm
Thanks thought that. Hopefully it sees me ok until tomorrow
jacky
Postby Sinisha » Tue Jan 10, 2023 1:47 pm
Most probably just voltage regulator/brushes to change
Sinisha
Postby metalworker0 » Tue Jan 10, 2023 2:38 pm
jacky wrote:Thanks thought that. Hopefully it sees me ok until tomorrow
no ..if using ......if you charge the battery overnight ..may give you 10 miles or so in daylight ..after that all sorts start happening ....first you loose your dashboard display ..rev counter stops working ...then other items fail to switch on: indictors lights etc
if it was petrol it would grind to a halt in 10 miles
so be careful ..10 miles in daylight only! after that things begin to pack up which may leave you stranded.
all the best...mark
Postby Altransit » Tue Jan 10, 2023 3:24 pm
all the best...mark
'Twas nearly 2 months ago Mark, hopefully it was sorted at the time 8)
