by mallood » Wed Nov 23, 2022 1:20 pm
Did you get it on?
You have the same set up like me, and the trick with these steched belt is.....put it on your alt. completly, ( so alternator must be installed and bolted down!) then from the top side of your cranckpully pul it as far as you can and then ty it up with a tywrap trough one of the holes near or below the furtherst side of where you got the belt....the tywrap can go under the pully so just make it tight and include the belt.....now cranck the car ( start) just one second....tada, belt is on and tywrap is broken lose.....if not repeat and make sure you got things tight down.
You can even find stuf on YT if you type in strech belt trick car, pully.......
i bet you allready fixed it but maybe next time you know the trick now......and for your alternator.....i dont understand why people change the entire alternator....take it of, listen to the bearing, if its sounds good then leave it, blow everyting with air and maybe some brake cleaner/ contact spray, and just change the rectifier, it costs peanuts compaired to a new alternator, and mostly the brushes are just worn., if the bearing sounds like sh*t you could even put on a new bearing, but for the rest, these copper wires hardly really fail.....you can open the rectifier and see if the wire brushes are stil long enough and make good contact.
anyway...goodluck
