Starting probs. Mk7
Starting probs. Mk7
Postby mk5mike » Tue Nov 22, 2022 9:20 pm
Hi guys Mk7 starting problem when I go to start it it will turnover and turnover and turnover and then try a second time it does the same I’ll try on the third or fourth time and it will fire in straight away. Run and start all day with no problems I’m thinking diesel problem any ideas? Thanks a lot cheers guys mike
It’s a 58 plate registered February 09 and also a recovery truck
mk5mike
Re: Starting probs. Mk7
Postby knobby1 » Wed Nov 23, 2022 3:02 am
Sounds like air in the system. Injector leak-off lines and O-rings, cracked filter head, filter head fittings have O-rings and it's possible for air ingress.
Check the fuel filter first thing in the morning, if it's empty, you've found your issue.
Postby mk5mike » Wed Nov 23, 2022 8:37 pm
Cheers pal. I’ll check Friday morning and get back to you
mk5mike
Postby mk5mike » Fri Nov 25, 2022 10:48 am
Hi pal
Firstly. Thanks for your time
Checked filter and fuel there, went to start it and just turned over for around 10 seconds and nothing. It did this twice and on 3rd time it fired in without issue
Tried it again and turned over twice without starting then fired on third crank. Strange
mk5mike
Postby knobby1 » Fri Nov 25, 2022 8:48 pm
mk5mike wrote:Hi pal
Are you getting cam/crank sync when cranking..??
Postby Uncle_Fester » Fri Nov 25, 2022 10:01 pm
Had a similar thing on a Renault dci with about 90k on the clockturned out to be injector no2 sticking open , therefore no fuel rail pressure,
(Mk7 2.2tdci jumbo highroof twin wheel 17 seat minibus.)
Uncle_Fester
Postby mk5mike » Fri Mar 31, 2023 7:33 am
Hi guys. Been working on this a while
Changed injectiors, pipes, fuel filter and housing done learns. Still the same
Any ideas
mk5mike
Postby knobby1 » Fri Mar 31, 2023 9:53 pm
mk5mike wrote:Hi guys. Been working on this a while
Any ideas
Loading up the parts cannon and throwing parts at it won't help, you need to find out why.
Are you getting cam/crank sync during cranking..?? What FRP are you getting during cranking..??
Why did you change the injectors..?? Were they coded to the PCM..??
Postby mk5mike » Tue Apr 11, 2023 1:05 pm
hi
i drove it home yesterday and started without fault, no issues driving went to it today and no start, what do i need to buy to test the pressure???
i have taken the pipe off that connects to the FPR and nothing comes out on cranking
mk5mike
Postby mk5mike » Tue Apr 11, 2023 2:42 pm
Just had it on my forscan and saw codes
P125a
P037d
And p608a
Thanks in advance for your help
Mike
mk5mike
