Good evening to all
At the ford dealership, they charged me 884€ to change the lock and a new remote key, so I decided to change it myself.
But I can't get the cylinder out.
I looked at the videos on youtube, I also saw a post here, I have come to the conclusion that I need to press the button shown in the photo.
First to write that the key is not working to the left (anticlock), i can't unlock the car, so i leave it unlocked.
1. First I removed the safety of the barrel.
2.I poured a lot of wd-40 and tried to push the button with a screwdriver, it won't go in, very little.
3.I hit it in a sensible way with a hammer and screwdriver, same thing again.
It is not pressed in any position the key is in the lock.
I disconnected the battery, because when I turn the key to the right (clock) it turns back automatically.
1.Are you sure this is the button to push in?
2.Is it the fault of the key that does not work on the left?
3.Maybe I should hit it harder with the hammer?
