Starter motor gone? symptoms/tests?
Postby DG-Unit » Sun Jan 08, 2023 12:30 pm
Happy New Year! Right. It’s 2023 so back at the van things finally. First up, it won’t start. I thought for ages it was a problem with the batteries and leisure circuit so I used my cutoff switch to turn them all off after use. I got some joy using a jump start pack but now it just clicks on ignition turn. Multimeter on both batteries (new last summer) shows they’ve got good charge. I’ve taken the leisure battery and relay out of the circuit just to rule that out. I can’t think of anything else but the starter motor now unless anyone has other suggestions?
2004 Transit SWB 85 T260
DG-Unit
Re: Starter motor gone? symptoms/tests?
Postby Altransit » Sun Jan 08, 2023 3:03 pm
Is the fused link earth lead under the seat OK? try bypassing it with a jump lead to test it :idea:
Postby DG-Unit » Sun Jan 08, 2023 6:26 pm
Altransit wrote:Is the fused link earth lead under the seat OK? try bypassing it with a jump lead to test it :idea:
I don’t think the mk6 has a fused earth unless i’ve missed it?
DG-Unit
Postby Altransit » Sun Jan 08, 2023 6:51 pm
It sure does, I still have the spare that I always carried in case of failure :shock:
Mk7 doesn't have it :)
Postby mallood » Sun Jan 08, 2023 6:56 pm
simple, just take it out, and connect a battery......make sure you hold it or clamp it.....now you know if it works. But should be possible to do with the motor still in the van, you just need to tip it with some juice to find out.
mallood
Postby DG-Unit » Mon Jan 09, 2023 10:21 am
Thanks. i’ll have a look at this after work before I go ordering a new starter
DG-Unit
Postby Chug » Mon Jan 09, 2023 10:25 am
It's worth trying jump leads direct from the battery to the starter and chassis/engine earth to check if the wiring is faulty.
Chug
Postby DG-Unit » Mon Jan 09, 2023 1:13 pm
Chug wrote:It's worth trying jump leads direct from the battery to the starter and chassis/engine earth to check if the wiring is faulty.
I’ve tried it to the engine earth and engine bay positive terminal but will see if i can stretch my leads to the starter terminal
DG-Unit
Postby DG-Unit » Tue Jan 10, 2023 5:21 pm
So I went to work on it and the starter battery was reading 20v. Thought i’d try starting the van and it went first time no fuss with the battery now reading 26v. I think the culprit is the 3-way battery isolator doing something funky to make the batteries parallel in a 24v circuit. Removed the leisure batter from the isolator and the starter is now back to 12v and van still starts no problem (for now).
So strange this started happening when I was only using the van 1-2 times a week after 6 weeks daily use roaming around France and Switzerland. I think I might need to get separate isolators for each battery.
DG-Unit
Postby knobby1 » Tue Jan 10, 2023 8:16 pm
DG-Unit wrote:So I went to work on it and the starter battery was reading 20v. Thought i’d try starting the van and it went first time no fuss with the battery now reading 26v. I think the culprit is the 3-way battery isolator doing something funky to make the batteries parallel in a 24v circuit. Removed the leisure batter from the isolator and the starter is now back to 12v and van still starts no problem (for now).
20v....26V..?? WTF..!!
That's pretty good for a 12v system. :wink: Not connected in series is it..?? Don't know how you'd connect 12v batteries in parallel and get 24v..?? :?
Postby Altransit » Tue Jan 10, 2023 10:35 pm
knobby1 wrote:20v....26V..?? WTF..!!
I don't know how you would have 20v plus running on the system without frying the electronics, and blowing all of the bulbs :shock:
Postby Chug » Tue Jan 10, 2023 10:51 pm
I jumped my transit from my Mercedes 814D which is 24v and got the connections wrong, it spun over ten times faster than normal and started straight up, it was only when I went to remove the jump leads and they were too hot too touch that I realised :oops: :roll:
Chug
Postby DG-Unit » Sat Jan 14, 2023 1:51 pm
It’s all a panicked mystery to me too
DG-Unit
Postby DG-Unit » Sat Jan 14, 2023 1:55 pm
I’m starting to think my multimeter is a bit wonky. I put it on the battery and it reads about 22v then slowly settles down to 14v…
Anyway. Thought i’d sorted it. Started the van up for the first time in 4 days, fired up no problem. Drove it outside my house to put some stuff in the back and will it start again? Will it f**k. It’s not even like it’s trying to start over now. I’ve given the starter motor a couple of hammer knocks but nothing. Got the jump pack on. Weird ‘test’ message keeps coming up on the dash and I’m stuck on double yellows on the wind and rain waiting to get a ticket :shock:
DG-Unit
Postby DG-Unit » Sat Jan 14, 2023 2:58 pm
Okay. The DTCs are in:
B1209 Instrument cluster switch bank 2 circuit failure
B1205 instrument cluster switch bank 1 circuit failure
DG-Unit
