Hi
2014 2.2 transit custom campervan
The van currently has a problem with the DPF and a faulty/stuffed up EGR valve.
It is going into the garage for a Terra Clean + diagnostics next Wednesday.
The van only gets short journeys most of the time but does some long journeys in the summer.
The handbook says that you can initiate a DPF clean but I can't seem to work out how this is done as when I follow the procedure nothing happens.
I am slowly learning about the DPF system and it appears that some scanners allow you to initiate a DPF clean.
I am looking for advice on the best scanner/s that will do this job.
all help welcome, thanks in advance
john
