matts09transit wrote:Hi all,
Thanks greatly for the replies - I appreciate it a lot. Yes it’s a MK7 2.4 RWD. Soz for double posting, trying to find the right place for technical faults. Tried to delete the other post but there’s no button?
@ noctule, not entirely sure tbh - do you have a reference vid of a functioning one?
Thanks all!
matts09transit wrote:So I didn’t hear a clicking and decided to give it a go. Ordered the part and got to it and snapped the bolt going to the EGR pipe (just as you said Noctule). Sad but I’ll give it a go and try to take it out with the pipe attached.
Came across another problem… can’t figure how to drain the coolant. Before I just clamped it but I guess I’ll need to drain it fully now. Had a look for the drain valve and can’t find anything like the + shaped notch it’s supposed to be - just a valve which doesn’t do anything when turned 90deg (see pic). Is the drain valve blocked? Any other way to drain it?
I’m enjoying it all but a lot of things are a first for me.
Noctule wrote:it's in his first ever post, but also i looked at the pic.
i take it you've only sprayed the wynn's in the air intake? that won't do much to clean the egr itself.
when you turn the engine off can you hear the egr running a cleaning cycle? whacka whacka whacka from under the bonnet. of not it can be stuck, knacked, or you have a wiring fault.
fisjon wrote:Is it supposed to do this every time?
