jasonblacktransit wrote:Hi all. just done a mk7 axle conversion onto my mk6. I need to do an abs bleed on it as no brakes after bleeding. Whats the best gadget to do the job at a reasonable price. How do you go about doing it, read loads of posts but no real description of how you do it.
jasonblacktransit wrote:Just want advice on the forscan and how you go about doing it
Frag wrote:I’m not sure that setup will work,
Drum brakes use a very small amount of fluid to move cylinders,
Disc brakes,on a master cylinder designed for drums,
