Transitcustom19 wrote:I’m in the middle of trying this from 4” base with no sync to sync 3 have u had any joy?
fabrizioroncato wrote:Transitcustom19 wrote:I’m in the middle of trying this from 4” base with no sync to sync 3 have u had any joy?
Hello, nope and a expert about remapping etc told me that it is not possible to install sync.
Let us know if you find something online that explains how to do that.
Thank you in advance
Transitcustom19 wrote:fabrizioroncato wrote:Transitcustom19 wrote:I’m in the middle of trying this from 4” base with no sync to sync 3 have u had any joy?
ake wrote:Upgrading to Sync 3 is very difficult, upgrading to sync 2.5 which has CarPlay, and can run a camera is not, and you can use the bits from a Fiesta!
fabrizioroncato wrote:ake wrote:Upgrading to Sync 3 is very difficult, upgrading to sync 2.5 which has CarPlay, and can run a camera is not, and you can use the bits from a Fiesta!
Thank you very much for your opinion
ake wrote:fabrizioroncato wrote:ake wrote:Upgrading to Sync 3 is very difficult, upgrading to sync 2.5 which has CarPlay, and can run a camera is not, and you can use the bits from a Fiesta!
It’s not an opinion its a fact
I upgraded my van to sync 2.5 using Fiesta parts and have advised a number of other people how to do it
To go to sync 3 would require a new wiring loom, APIM, AHU, Display and lots of programming
ake wrote:You need an ahu, sync 2.5 screen and lead, usb hub and lead and the dash centre panel to suit, and it will all plug in and work
