Mk7 sport engine
Mk7 sport engine
Postby Robbra2507 » Tue Feb 07, 2023 11:53 pm
Hi im new here and am looking for some help.
I have a 2012 mk7 sport 2.2 pgfa. It had diesel run on and have been told it is knackered and I need a new engine. Was told that all the transit engines are the same and I could put anyone in my van and its the turbo and ecu that gives the different bhp. Is this correct or do I need to get the same engine that is in it already? Any advice information or help would be much appreciated.
Thanks Robbie
Robbra2507
Re: Mk7 sport engine
Postby knobby1 » Wed Feb 08, 2023 12:53 am
Robbra2507 wrote:Hi im new here and am looking for some help.
Thanks Robbie
On the Euro-5's, yes...all the basic engines in the FWD's are the same.
Postby Robbra2507 » Wed Feb 08, 2023 2:11 am
What about the euro 4? That is what mine is sorry forgot to mention that.
Robbra2507
Postby knobby1 » Wed Feb 08, 2023 10:04 am
Robbra2507 wrote:What about the euro 4? That is what mine is sorry forgot to mention that.
You said it was a 2012, if that's the case it will be Euro-5. Anything "built" from September 26th 2011 will be Euro-5.
What's your actual "build date".?? Not the reg date.
Postby StevieCustomSport » Wed Feb 08, 2023 10:17 am
Hi, I have had exactly the same happen to my 2014 Custom Sport last week!
I have found an engine that is a CYFF E5, although my V5 states mine is a CVFF.
I forgot to add the seller said the engine came out of a 2017 custom, but it is a 2.2 FWD E5
Does anyone know what the difference is? Thanks
StevieCustomSport
Postby Robbra2507 » Wed Feb 08, 2023 11:39 am
Where will I find the build date? On the v5 it Says version euro4a3eu ea. That's where I got it was a euro 4.
Robbie
Robbra2507
Postby Altransit » Wed Feb 08, 2023 2:07 pm
Robbra2507 wrote:Where will I find the build date? On the v5 it Says version euro4a3eu ea. That's where I got it was a euro 4.
Robbie
Have a look at the injectors, and post back with the make.
Knobby (or someone) will know which version it is, from that info.
Postby Altransit » Wed Feb 08, 2023 2:12 pm
StevieCustomSport wrote:Hi, I have had exactly the same happen to my 2014 Custom Sport last week!
If it's 2.2 euro 5, all the engines are the same, (but presumably RWD are different?)
The later euro 6 engines are 2 litre, and can't be substituted.
Postby knobby1 » Wed Feb 08, 2023 8:00 pm
Robbie
What Altransit said...if you can post a pic of the injectors, we'll then be able to tell you for sure.
Build date should be on a sticker in one of the door shuts...similar to this one on mine which is a June 2008 built machine and Euro-4..:
