abs bleed
abs bleed
Postby jasonblacktransit » Sat Feb 11, 2023 11:07 am
can anyone help.......mk6. 2.4 rwd..bled abs pump three times with forscan and still no pedal
jasonblacktransit
Re: abs bleed
Postby Frag » Sat Feb 11, 2023 2:30 pm
No pedal at all,or lots of travel ?
With or without engine running ?
It could be the seals are shot in the master cylinder,or have torn / failed since trying to bleed it after swapping axle.
If you clamp the flexi’s to rear axle (without damaging them) do you have same fault ?
Frag
Ford Technician
Re: abs bleed
Postby jasonblacktransit » Sat Feb 11, 2023 2:48 pm
the pedal goes ok with engine off but goes to floor with it running. i cant clamp rear flexi pipes as i am using the mk6 copper ones
jasonblacktransit
Re: abs bleed
Postby Frag » Sat Feb 11, 2023 3:00 pm
You should have flexis between body and axle,and again between axle and callipers ?
If you’re getting lots of travel,are you sure the rear pads are in correct,with the locating peg on inner pad lined up with cut out on the piston ?
Frag
Ford Technician
Re: abs bleed
Postby jasonblacktransit » Sat Feb 11, 2023 3:08 pm
i have just clamped flexi pipes at back and now have a good pedal
jasonblacktransit
