Fuel gauge on empty when tank is full
Postby nadimchenia » Fri Mar 17, 2023 3:38 pm
Hi everyone, i would really appreciate some advice please, i have a ford transit 350, reg is NL64 AVB, every now and again the fuel gauge is shooting to zero even when we have diesel, the van then cuts out as the gauge is showing zero, then we can fix the issue by giving the fuel tank a few bangs, which then takes the gauge back to its correct level, can anyone tell me what exactly the problem may be? I am just trying to work out what part i need, and where i can but it from.
Thanks so much in advance, Nadim
nadimchenia
Re: Fuel gauge on empty when tank is full
Postby knobby1 » Fri Mar 17, 2023 9:56 pm
Sounds like the gauge float in the tank is sticking. Tank out job to fix unfortunately.
The system will shut the engine down if it senses very low or no fuel, this helps prevent high pressure fuel pump damage due to no lubrication.
Postby Rollingbob » Tue Jun 04, 2024 6:35 pm
What do you mean sticking Knobby?...i'm getting this after taking out sender to inspect seal. Guess i didn't put it back properly somehow - was fine before lol.
Rollingbob
Postby knobby1 » Tue Jun 04, 2024 8:43 pm
Rollingbob wrote:What do you mean sticking Knobby?...i'm getting this after taking out sender to inspect seal. Guess i didn't put it back properly somehow - was fine before lol.
The "float" on the sender unit itself can possibly get hooked on a rib or something in the tank or the steel wire holding it can get bent causing a miss-read.
The old-school fuel tank sender units had hollow floats which could split, fill with fuel and sink to the bottom of the tank...which would always indicate the tank was empty.
Postby Rollingbob » Tue Jun 04, 2024 9:55 pm
Right thanks. I think its got hooked down by the diesel heater sender pipe (long metal one) which is right next to it.
Rollingbob
Postby knobby1 » Wed Jun 05, 2024 12:15 am
Rollingbob wrote:Right thanks. I think its got hooked down by the diesel heater sender pipe (long metal one) which is right next to it.
That could do it..!
Postby Rollingbob » Thu Jun 06, 2024 1:25 pm
Hooked on the bottom of the sender unit itself
Rollingbob
Postby nadimchenia » Tue Apr 08, 2025 11:09 am
knobby1 wrote:Sounds like the gauge float in the tank is sticking. Tank out job to fix unfortunately.
Thank you very much for the reply, is it something that can be fixed? or should I get a new sender unit?
thanks in advance, much appreciated
nadimchenia
Postby nadimchenia » Tue Apr 08, 2025 11:10 am
nadimchenia
Postby knobby1 » Tue Apr 08, 2025 8:08 pm
Hmmm, has been well over 2 years.....Have you actually removed it to have a look to see if it is actually sticking, damaged or hooked on something..?? Yes it can be fixed....but you need to know what to fix first.
