viewtopic.php?f=54&t=221062
Hi,I'm seeking some diesel experts who can give me some tips to start my rebuilt 1.8tdci engine - i originally posted it in the connect forum (see link above) but perhaps someone on here might see it and have some ideas for me to try before i finally give up and scrap it. it's a 4 page post with videos on my youtube channel so i appreciate it if you have the patience to read and watch it all!
In short,it suffered a cambelt snap while it coasted up to some traffic lights. damage wasn't too bad;some bent valves and dented piston cylinders - engine out and everything replaced with new bottom block gaskets,head gasket etc.
followed everything to the book,particulary the all important timeing,careful with not running diesel pump dry.
engine is all assembled and no dtc's present, forscan software shows its cranking 250rpm and looks all positive to start but she will not catch,not even cough with easystart.
last thing i've tried is some oil down the glowplug holes and still no joy,compression readings cranking her on the starter while jumping her with oil down there reported approx 50psi on all cyls.
I am willing to give it one last shot and whip the head off and replace the head gasket one more time with new bolts,set timing etc but before doing that i wondered if anyone has any smart ideas first since.
many thanks
Mark
