gearbox oil
gearbox oil
Postby CLL » Mon May 29, 2023 7:37 pm
Time to change gearbox oil... looking at an old post on here (which of course somehow I can't find now) it said most models took WSD-M2C200-C. There was also the VMT-6, which takes 200-D2, but it said this was front wheel drive.
I have a 2013 2.2 RWD, so I thought...I obviously need the 200-C.
I then go on to Opie oils, put in my reg etc, look up gearbox oil, and.......it gives me 2 different oils...both 200-D2.
Is the post wrong and I need 200-D2? Or is Opie oils wrong and I need 200-C?
Any help greatly appreciated.
CLL
Re: gearbox oil
Postby knobby1 » Mon May 29, 2023 8:15 pm
CLL wrote:Time to change gearbox oil... looking at an old post on here (which of course somehow I can't find now) it said most models took WSD-M2C200-C. There was also the VMT-6, which takes 200-D2, but it said this was front wheel drive.
If yours is a 6 speed, which I suspect it is being a Euro-5....it'll be a variant of the MT-82 gearbox, the Ford spec WSD-M2C200-C oil is nothing special and any good quality 75W80 synthetic gear oil will work fine. I've been running Redline synthetic 75W80 in my MT-82 for several years without issue.
Re: gearbox oil
Postby CLL » Tue May 30, 2023 9:25 am
Cheers Knobby. Yes, 6 speed. I'll just go for putting a decent fully synth 75 in.
I had a look at other sites online and put my reg in to see what came up. Interesting that they ALL said FE 75w, WSS-M2C200-D2.
CLL
Re: gearbox oil
Postby dumper » Tue May 30, 2023 3:59 pm
Hi my lordship is that the same oil for my mk8 2.2 rwd cheers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: gearbox oil
Postby knobby1 » Tue May 30, 2023 8:26 pm
dumper wrote:Hi my lordship is that the same oil for my mk8 2.2 rwd cheers
Should be, the gearbox is the same as the Mk7 RWD 6 speed, a variant of the MT-82.
Re: gearbox oil
Postby dumper » Wed May 31, 2023 7:43 am
Cheers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
