Air con losing cold air on acceleration
Postby Kellym » Tue Jun 27, 2023 1:34 pm
Hi.
Help please. Even mechanic currently scratching heads. I have an issue where the air con cold air warms up a bit on acceleration. I drive city roads so am pretty much always accelerating. Garage regassed but no change. I originally thought the air was changing speeds on acceleration as it sounds different although I’m told I have bat hearing. Any ideas?
2015 custom if that helps
Kellym
Re: Air con losing cold air on acceleration
Postby Altransit » Tue Jun 27, 2023 1:36 pm
All I can think of is that the belt that drives the compressor is slipping, or the comp. clutch is disengaging :?
Postby metalworker0 » Tue Jun 27, 2023 6:50 pm
or actuator flaps (if it has the motorised type) have stripped gears (very common so flopping about ) and on acceleration...is pushing air into the van and pushing flaps into hot position .
