Long story very short, a Land Rover mechanic mate has potentially found the cause of a juddering while slowly manoeuvring the van, such as parking.
Van is a mk8 4x4 2.2 125ps with 150k miles and he thinks (again, long story short) it likely an oil change in the front diff could sort it out.
This is where things get interesting. Ford state that the Transmission Oil (75W FE 7U7J-M2C200-BA/CA/DA) has the reference WSS-M2C200-D2, whereas the Gear/Transmission Fluid (SAE 75W-90) is the more common GL-5 (screenshot of spec attached).
Ford do an OEM oil for both, but the WSS-M2C200-D2 appears to be purely an oil for a manual transmission whereas the GL-5 is used in rear axles and 4x4 transfer boxes.
I thought WSS-M2C200-D2 was likely the correct oil but seeing the designed use for the GL-5 has made me second guess, and I want to be sure I will be putting the correct oil back in the diff.
Does anyone know which is the correct oil to use? Thanks.
