2005 transit connect 1.8 tdci
Postby roundtuit » Mon Aug 07, 2023 4:59 pm
at my wits end with my 2005 connect, replaced clutch and slave cylinder, master cylinder, nightmare to bleed but finally got it...2 weeks later pedal went straight to floor now wont bleed constant stream of air. using bleed system that runs of compressor, could it be the resevoir or pipes.
roundtuit
Re: 2005 transit connect 1.8 tdci
Postby metalworker0 » Mon Aug 07, 2023 6:43 pm
clutch pedal is meant to go to the floor ..are you talking about the brakes?
Postby roundtuit » Mon Aug 07, 2023 7:00 pm
clutch pedal fully depressed will not return and will not go into gear
roundtuit
Postby metalworker0 » Mon Aug 07, 2023 7:40 pm
Haven't been there, so really cant give you any experience ..
a few weeks ago there was a thread in the transit connect forum ..it talked of seals - o-rings ..plastic cylinders, loctite, compatibility ..maybe read it ..
viewtopic.php?f=54&t=223052&hilit=clutch
and a shout out to andz327 as he seams to know a lot about it.
