by Airthies » Tue Aug 08, 2023 9:58 am
Personally I find they confuse issues rather than direct you to a solution.
There's other data, tools and codes which will be of more use for solving problems.
If it's showing a fault on injector 4then one option is to swap injectors 3 & 4 to see if fault shifts.
It's always recommended to replace the stretch bolts and injector washers but for a test I've risked using them again.
Bolts from ford are cheap but copper washers, not so much.
Sent from my S99 using Tapatalk
2008 350LWB 115PS ex fitters van "retired"
Bikes, yes, a few bikes.
V86+patchV86.04X-ProgC81
